Fuel Flow Problem - Honda Forum : Honda and Acura Car Forums
Go Back   Honda Forum : Honda and Acura Car Forums > Honda Lifestyle & Entertainment > Honda Off-Topic Lounge > R/C & Model
Old 10-28-2008, 03:37 PM   #1 (permalink)
CapnToll's Avatar
Car: 1996 Integra SE, 2014 S5, 2017 C63S on the way
Mods: See the sig.
CapnToll you're still here?CapnToll you're still here?CapnToll you're still here?CapnToll you're still here?CapnToll you're still here?CapnToll you're still here?CapnToll you're still here?CapnToll you're still here?CapnToll you're still here?CapnToll you're still here?CapnToll you're still here?
Fuel Flow Problem
Hope a few people still come around here....
.15 Nitro motor with Piston/Rod/Sleeve from .12 motor.
The motor is spitting the fuel back into the fuel tank. It really does not want to vacuum the fuel down the line into the motor. I've tried leaning, enriching, throttle body play, leaving the glow starter in.......still only runs for a few seconds while it spits out the fuel back into the fuel tank.
I thought it was just a gravity thing cuz my fuel line was looped upwards. Fixed that, and fuel flow seemed to improve....but that's just because my needle was way lean keeping the fuel in the lines while it was unstarted using the fuel pump.
Maybe it's a bad glow plug? I thought it would stop every time I removed my starter, but I think that was just the fuel flow issue. My next step would be replacing the glow plug....
Any thoughts?
Resident Mechanical-Automotive Engineer, B.A.Sc., P.Eng.
Integra: 173whp, S5: 380awhp
CapnToll is offline
Old 11-08-2008, 01:26 AM   #2 (permalink)
Super Bacon Mod
VTECsqznN2O's Avatar
Car: 1990 SI Hatch
Mods: Bottle Fed B16A [email protected] on I,H,E and a 50 shot
check for air leaks in the pressure hose from the pipe to the tank
1991 Acura Integra - *SOLD*
2012 Civic EX - DD
In the end, everything we do is just everything we've done
VTECsqznN2O is offline
Old 11-08-2008, 06:14 AM   #3 (permalink)
Cypher Wave
ATISTANG's Avatar
Car: 79 Yugo
Mods: Fuzzy dice hanging in the mirror, chrome hub caps, oversized waabaa valves
is the piston from the .12 motor to big for the .15 bore?
maybe all the fuel is coming through the crankcase into the cylinder and strait into the exhaust causing it to end up back in the fuel line
ATISTANG is offline
Old 11-08-2008, 08:08 AM   #4 (permalink)
CapnToll's Avatar
Mods: See the sig.
I've been running the car like this for 2 years now, so I know my internal swap is fine. I got a new glo-plug, and it's fine.....but the plug is like....half a millimeter too long somehow, so the piston hit it a couple times....no damage, but it obviously seized. The sleeve came up out of the bore a bit. But unscrewing the plug even a bit loses all compression, so I'll need a different sized plug.
The bigger fuel return line I put in helps with the vacuum as well. If I still have problems I"ll tear down the entire motor, and rebuild.
CapnToll is offline
Old 11-25-2008, 09:04 PM   #5 (permalink)
Car: 1994 civic EX
Mods: nothing special ;)
Anomoly you're still here?Anomoly you're still here?Anomoly you're still here?Anomoly you're still here?Anomoly you're still here?Anomoly you're still here?Anomoly you're still here?Anomoly you're still here?Anomoly you're still here?Anomoly you're still here?Anomoly you're still here?
you need to fix the plug clearance issue first off, then clean the carb
Anomoly is offline
