Go Back   Honda Forum : Honda and Acura Car Forums
Honda Forum : Honda and Acura Car Forums (https://www.superhonda.com/forum/index.php)
-   D-Series Tech (https://www.superhonda.com/forum/forumdisplay.php?f=87)
-   -   OEM D-Series Piston Information (https://www.superhonda.com/forum/showthread.php?t=189022)
kommon_sense 10-14-2004 02:50 PM
I came across this info on another forum and copied the info here. It was just too good for it only to reside in one place. Thanks to Sonny who originally posted this information on HT.
You may want to play with the D-series compression calculator after reading this post :
http://www.knology.net/~jediklc/D.htm
You can click here to See a Diagram of Piston Specs.
Additional piston specs are available here : https://www.superhonda.com/forum/show...postid=1207532
Late Model D-Series Piston Archive is available here : http://heeltoeauto.com/httech/YaBB.p...1160787887/0#0
Originally Posted by Sonny
Hi All:
So far, I have 6 different D series pistons to work with. I have almost every piston from 1.6 liter engines. I think I'm missing one from the 96+ Civic HX, but nobody has that car. :p
Here are the contenders so far:
https://www.superhonda.com/photopost/.../11214pg6b.jpg
https://www.superhonda.com/photopost/...1/11214p29.jpg
https://www.superhonda.com/photopost/...1/11214pm7.jpg
https://www.superhonda.com/photopost/...1/11214pm6.jpg
https://www.superhonda.com/photopost/...1/11214p28.jpg
https://www.superhonda.com/photopost/...1/11214p2p.jpg
I've measured the P29 and PM7 pistons in several ways and as far as I can tell, they are exactly the same. I wonder why Honda made 2 different part numbers and castings for the same piston? Hmmm...
Sonny
kommon_sense 10-14-2004 02:53 PM
The main motivation behind this project is to determine what compression ratio is yielded using different combinations of D series pistons and D series heads. There is such a large variance in the way that Honda designed the pistons that just about any compression ratio is doable.
For example, the PG6B (86-87 Integra) and the P28 (92-95 Civic) both have the same compression height (1.181"). They will be flush with the top of hte block when installed. However, the Integra piston has a small dome, but the Civic piston has a HUGE dish. The difference between the 2 pistons afa compression ratio is very large.
Here are some pics comparing the P29 (88-89 Integra) to the PM7 (88-91 JDM ZC). This Integra piston was slightly modded on top, but I've seen a very clear picture of the top of this piston and can say that it is identical in shape to the PM7.
https://www.superhonda.com/photopost/...pm7vsp29-1.jpg
https://www.superhonda.com/photopost/...pm7vsp29-2.jpg
https://www.superhonda.com/photopost/...pm7vsp29-3.jpg
Sonny
kommon_sense 10-14-2004 02:55 PM
Ramkatral 10-14-2004 09:39 PM
Great, the one piston he doesn't haev is the one I need to see. :cry
Hondadog 02-15-2005 03:45 PM
Great thread kommon.
kommon_sense 03-09-2005 05:31 PM
The ultimate d-series piston archive is back up :
http://www.heeltoeauto.com/tech/dseries/dseries1.shtml
I'll work on pulling this info into SHO so that we have it archived in case it goes down again.
kommon_sense 05-07-2005 10:55 PM
4dr 05-07-2005 11:05 PM
*wink*
we got all the good stuff. =)
kommon rocks for the effort he puts in here. u guys should love him.
civic_x_95 01-31-2006 11:57 AM
Why isn't this stickied? This should be stickied.
kommon.... you are teh shit. :hug
