I had to take the driver side seat out of my 03 pilot and it has the side air bag. When I put the seat back in the srs light is on and will not go off. I tryed disconnecting the battery and it is still on. I tryed to pull the fuse and s]disconnect the battery and nothing. I called the dealer and they said $100 to reset it. Any help would be great, I dont want to spend $100 for them to do 2 min of work. Again any help would be great. Thanks.
Discussion Starter · #5 ·
Got it here is a sight. http://www.**********.com/zerothread?id=264288
Also if you disconnect the battery you have to reset the auto window up/down. To do this turn the car on but do not start it, make the window go up and down like 3-4 times on the 3rd or 4th time hold the button down for 5 seconds when the window is all the way down, do the same when the window is all the way up. Turn the car off then start it like normal and it should work just fine.
