My car is going to hit 100,000 miles in like a week or two. I'm going to replace the timing belt, plugs, wires, clean the air filter, and change the oil and oil filter is there any thing else I should do?
I know AEM makes a after market fuel filter or are all fuel filters the same?j0e said:fuel filter..
A good lube what is involved in a good lube?SuperBlueSi said:The timing belt should have been replaced at 60,000, if it was it should still be good for another 20,000. Don't forget to flush radiator, check the fluid levels, rotate tires, get a good lube, check the boots, check brake pads and lines, replace plugs and wires.
I thought that automatic transmissions had fluid. I have a five speed. I don't think I can add fluid to that can I??uncald4 said:Hey BRO.
Mine is about to hit 200,000 in about a month. more important at this point is your tranny. The engine will go for about 120k just fine. TRANNY FLUID. Get it don now! Or you will not get much farther.
drewmilladakill sorry i don't know who you aredrewmilladakill said:Wojo101280 i have seen you around in catonsville, i drive the silver civic with blue vinlye, do you know who i am?
