100 idle
717 Views 5 Replies 3 Participants Last post by  Fosgate13
I just did a swap into a 93cx. jdm b18c. first off it idles at 100rpm and then if you give it gas it cuts off immediatly. does anybody have any idea what could be wrong? i mean it will idle by itself but at 100 for a while.
first off is the ecu thowing any codes?...second check the IACS.......
you need to fix those problems because they could be the reason that is it idling like that (although i dont think its likely).......like i said Idle Air Control Screw
that would have nothing to do with the car cutting off when i hit the gas hard.
Check your air fuel. make sure its right but its sounds liek an ignition problem. did you make an external coil on it?
F13
