1 - 14 of 14 Posts
If I were to put 17s on my Lude, what ride height would be good? Also, I know that the speedometer gets thrown off when you put bigger rims on, is there a way to fix this?
~Peace :D
The speedo doesnt get thrown off if you keep the total diameter the same (ex. 15" rims with 60 series tires = 17" rims with 40 series tires)
I have 17's and with a good offset I wouldnt go any lower than 2"
You can do the calculations if you want to play around with it.
If you stay within 2% of the stock tires size, you should be fine.
For example, stock size = 205/55/15.
205 * .55 = 112.75 mm (height of 1 side wall)
112.75 / 25.4 = 4.4389" (to convert it)
Multiply that by 2 = 8.8779 (2 sides)
Add 15" (the size of the wheel) = 23.8779" - total height of the wheel and tire.
a 205/40/17 = 23.4566" - a good setup
Discussion Starter · #4 ·
Thanks people! Also, what is the widest rim I can put on the lude w/o it sticking out of my wheel wells.
~Peace :)
Biggest rim and tire combo that I would put on a 4th G with a mild drop is 215/40/17's on a 17X7.5" rim. You will NOT run into any clearence issues with that and your speedo will not have to be recalibrated.
this is exactly what i have.....and i have a 3+ inch drop..dunno exactly how much...just on the lowest setting...no problem with tires, just the kit being scraped when i get out of my driveway
one of my friend just got sum 17in SSR competition for her 5th gen and theyre one of the best looking rims for prelude ive ever seen , really nice :)
Re: One more....
racerpunkX said:
I totally dig the look of this exhaust......Remus twin tip.....but I'm gonna put off any exhaust costs till I go turbo.
that car looks like a _______________(enter ethinic appropriate ethnic group there) car....the tires are too wide...and probably weighs a ton..
some cars look ok with the wheels sticking out of the wheelwells...but not preludes.
1 - 14 of 14 Posts
