Hi, I have this oscillating problem with my idle and I pretty much checked everything including the TPS. The problem is that I don't know what my voltage should be with a close TB and at WOT. I got 0.24 Volts with a close TB and 3.03 Volts at WOT. Can someone point me the right direction. Thanks!
well your tps voltage should be .5 at closed and 4.5 at wot check for a vacuum leak and also check ur iac valve
