Previous owner did a ebay turbo on my d15b7, with a manual shift. I went threw all the vacuum lines made sure it was timed right, when idling it will drop down like its got a cam in it, when in boost the check engine light comes on and it runs perfect, running and 8lb spring on stock injectors so far and purchased the normal upgrades 450cc injectors , high flow fuel rail, 290 fuel pump , and a chip to tune as well as a new idle control valve, will this fix the issue?
