1 - 16 of 16 Posts
anybody have a turbo charged 4cyl
did you forge your pistons?
bore the block?
how much boost are you running on the stock internals?
did you buy the kit, or buy the parts separate?
any problems?
Heres what one guy did.
Stinker’s Full F23 Build - everything-honda
F engines are known to hold up reliably at 220-240 hp when tuned correctly.
Boost is kind of misleading, because 10 lbs of boost at 120 degrees versus 160 degrees is a signifigant difference. Two people my both produce 10 lbs of boost with identical setups, but one may have a much better intercooling system, which would make more power.
You might want to check out the forced induction forum for turbos here: TurboCharger - Honda Forum / Acura Forum - SuperHonda.com
If you want some information on turbocharging use the search, I've made sereral posts with good info about turbocharging.
F23 Strong Motor
I been boosting for almost 3 years now on a turbonetics kit. With stock bottom end at 8 psi I dyno at 212whp 202wtq with a 12:1 air-fuel mixture. I use 93 octane gas I rise my boost to 10.5psi and took my exhaust out runing a open down pipe. Taking my car tomorrow to get dyno I hope I make 240whp!!
Discussion Starter #5
sweet man, how much did that run you? and u have the inline 4? pushing 212whp?!?
Super Ban-Finger Mod
212whp isn't a lot...don't get super excited about that. there are other 4cyl motors that make quite a bit more...and they're NA.
but before you go boost happy, you should really look into what it all takes to run a turbo in a car that's not meant to be turbo.
Darth Chinko
you don't have to brag about me baby
note the end of the sentence. boost doesn't count ;)
F23 Made More Power
Got my car dyno today I made 236WHP!!! 224WTQ!!! At 10PSI and open down pipe Iam vary happy with my numbers. The turbonetics kit was about $3,690 I will post my dyno shreet tomorrow.
Hmmm... I have an inline 4 and guarantee you will get pwnt. Numbers aren't that great mate. Take it to the track and see where the bidness really sets.
i'll boost in your mouth mister mod :p
HAHAHA, you crack me up.
I'm wondering where that Dyno sheet is @.
On a side note purchased MSD wires for 52 bucks instead of 80-90 from an autoparts store, only need everything else for the turbo setup... dammit.
lmao.:lol
:lol
kf4hoq; said:
Clayton...is that sheet for your truck?
shit no.. mine only makes 450/600. i was just chuckling @ the idea that 210 or whatever was a lot of power.
I was wondering!! I got to looking at that and was like 'holy shit'!! That's a far cry from my '87 F250 with the old 6.9L non-turbo diesel with 185HP and 318LB-FT!!
1 - 16 of 16 Posts
