Any other ideas? I would like to wait for the type R, but uncertain when it will be available.......
By going N/A you don't have to worry about anything having to spool up to get your power? That's fine, you just won't have any power at allLsVtecR said:yeah but by going N/A you don't have to worry about anything having to spool up to get your power. just step on the gas and lay down the law.
That is why you should always make sure to buy all the necessary turbo management parts. That way you know when something's wrong before it's an issue. By this I mean electronics. I wouldn't be comfortable running a turbo'd setup without the the following:LsVtecR said:true a turbo will give the car more power, but in the long run it could cost you more if you blow your shit.
Why that point.......jujubee said:What would it take to be in the 13's all motor?
Dude, you are either full of isht, or you don't know how to drive.GrooveMaster said:I had a heavily ported head with titanium retainers, double springs and lighter valves, a modded(jun) ecu that reved to 9000 rmp's and some nice Jun "b" camshafts. I was able to lay down 202 at the wheels with a ITR USDM tranny and lsd, and did a 14.29 at the track with some weight reduction. It was NOT cheap, i just pulled all of it out about 2 months ago for a JRSC. I had to go back to a stock head and ecu, but I was able to sell the modified head to offset the cost of the blower and accessories. I am doing between 220 and 230 at the wheels now, I haven't been able to dyno yet, I still need to lighten the flywheel, and I think I am going to change out the JR FMU for a modified Cartech unit. Just my $0.02 Jim
CTR pistons in a stock GS-R head/block is about 12.5:1 static compression, high, but can be made streetable with good tuning, and high overlap/aggresive cams (that way your dynamic compression is lower).blkgsr1 said:I'm looking at adding a fairly radical cam, cam gears, port/polish head, Hondata, Quaife, etc. that should turn about 200 whp on the dyno. My question is about what should be my 0-60, quarter mile time and speed. I would like to stay n/a. I am also looking at changing to ctr pistons, so altering compression.
