1 - 15 of 15 Posts
kommon_sense said:
:stupid . The 60series will be about 1.5" wider than the correct size wheel for your car. If you like the muddin' offroad look then go for it.
wider or taller? the aspect ratio (the 60 or the 50) has nothing to do with the width (the 205) just the overall hight of the tire.
the height as a ratio of the width. so it is related, but it doesn't affect the width it is a result of the width.
plus with the 60 series, you'll be going faster than the speedo says. with the 205/50's you'll be off like less than 1mph.
yeah its will be taller not wider
handling will suffer with those tires but the ride should be a lil more comfortable and you dont have to worry about bending the rims if you hit any pot holes.
Ok here you go
195's = thinner so less road noise and a all so very slightly(not even worth mentioning but you are asking for pro's and con's) more aerodynamic( :hehe )
205's = Slightly better grip, lil more tire noise, lil heavier
1 - 15 of 15 Posts
