is there a bulb for this? not sure. if so how do you change it?
i noticed today driving home from work that the center clock above the A/C console is dark. i remember being able to see the time? hard item to do? if its just a bulb replacement can i buy this bulb at pepboys? or is it a dealer only item due to its size? just a note...no led swap here. its my moms car
thanks!
yes, there is a light......look on ebay for it, i bought a replacement for a dollar. To replace it, just pop the clock mounting out and you should see a little circular plastic thing mounted on the side of the clock. Use a flat head screw driver to remove it, then put the new one in. very easy to do, shouldnt take more than two minutes.
