I have a 2001 accord I was going to replace the springs with a set of eibach pro-kit. I took half of the front of the car apart, and I couldn't get the front stabilizer bar off. The nuts on the lower control arm just keep spinning, does anyone know what I'm talking about and know what to do about it.
should be an allen bolt. You stick the allen wrench in and use a open ended wrench to get the nut off.
Hope that helps.
Thanks a lot man, the shop wanted like $250 to put the springs in.
Discussion Starter #5
Really I couldn't get the lower control arm to drop off of the shock with it on. Is there another way?
