car has 82k miles. i really like this car and there are no good small hatchbacks in the USA (except GOLF, i don't like so much)
would it be worthy to upgrade struts/springs to aftermarket ?
what brand/model ?
i don't want to lower the car, i'm only wondering if i can get similar feel as driving 2008 Subaru outback for example. the suspension just feels so much nicer. i wonder it it's because my car is old and the suspension progressed so much or i can just upgrade.
i had the car inspected my firestone - the factory struts have no leak and all seems fine.
just the feel is far from newer cars.
what brand/model ?
Most Honda struts will last over 100,000K and won't be worn out at 80K.
A Subaru Outback will have a suspension ride that is less harsh. Part of it has to do with the wheelbase, it's longer than the Civic.
Replacing your Civic with OEM struts will give you a factory ride. Most struts that are an upgrade will tighten up the suspension for a sportier ride. There are air suspension kits out there, but I don't know anything about them.
to lower it on air and actually have it low requires a lot of money and work. if the OP has deep pockets and can fab up new struts all around, thats what I would do.
Suspension
Go with coil overs. You can choose a comfortable spring rate, and control the hiegth. Tein, BC, and a few others would be a good choice. Don't go cheap.
Darth Chinko
i wouldn't get any of those if a factory feel is what you want. koni yellow with gc sleeves... fyi civics have coilovers from the factory.
