Is this the same fitment as a regular 2002 Civic? As far as I can tell they are, but OEM differs. I imagine spring rate, and dampening are a bit stiffer on the OEM Si part. Can anyone confirm fitment is the same?
Discussion Starter #2
I got some from a crappy auto website, and they did fit although one had to be disassembled to rotate the top 180 degrees so it would fit on the other side. Rides awesome now. It turns out the previous owner cut the stock springs down to lower it. Ugh.
