Finally, something that deserves that Cobra badge. 390 (most likely underrated) horses, a 6spd, better handling, and an underrated 390lb-ft of Tq to boot and many more. Took long enough.
390hp @6500
390lb-ft @3500 rpms. 300+lb-ft at 3k rpms.
Both are most likely underrated. I've heard a guy over at cz28.com say he's seen/heard of one put down 36Xhp and 385lb-ft of Tq to the wheels on a dyno test (over at anderson ford). They also tested the Mach 1 and bullitt before. That equals to about 425hp and 450lb-ft of Tq at the crank, if what he said holds true. Should be a solid 12 second car that'll trap at 110+mph and that'll also pull .90+ g's on the skidpad. Price will be $35,000 for the coupe, which is not bad at all.
Specs go here - http://www.bonforums.com/mustang/cobra_03presskit/
390hp @6500
