1 - 17 of 17 Posts
Pontiac won’t apologize for the fact that this car doesn’t look, feel or perform like the car for which it was named. It has a V8, sure, but it doesn’t even come from the same continent. So to all of you looking to the resurrected GTO as the second coming of a sacred old nameplate, too bad. This ain’t your daddy’s GTO, and no, it doesn’t have a hood scoop, not even of the sticker variety with which Pontiac jokingly threatened us. You’re better off picking up any one of a thousand 30-year-old models still spewing fumes around the back roads of this great nation and being done with it. But keep this in mind as you grip that skinny steering wheel, slide around in that seat and lumber around the turns: The new GTO bests that old beast in every noteworthy way. Except one, that is.
Man, that old goat looked good.
The 2004 model, hmmm, not so much. We—and many of you, we’ve heard—find the GTO’s exterior styling utterly forgettable, if not exactly ugly, and hardly reminiscent of its namesake. Pontiac says that’s intentional. Rather than designing a “retro” car, Pontiac says it likes to think that, had it not killed the GTO after the 1974 model year, the Goat would have evolved to look much like this car today. (Kind of convenient, then, that the General already had a car exactly like it hiding out Down Under.)
LOOKS AREN’T EVERYTHING, BUT THEY’RE A LOT
In fact, the GTO looks virtually identical to the Australian Holden Monaro that forms the basis for this car, save the addition of Pontiac’s signature split-kidney grille. Most of the changes made to the Aussie car when Bob Lutz ordered it up for these shores occurred where you can’t see them, from improved door and window seals to modified knee bolsters and restraints. Oh yeah, and the trunk houses the fuel tank (moved from under the car; too bad for you golfers). Noticeable in its absence: any cladding.
It seems the Excitement division finally heeded all those pleas for clad-free design—hallelujah!—but alas, took the move to an extreme by doing nothing to gussy up such dull sheetmetal. The car’s flanks have a too-smooth shape, and its rounded-over nose and tail feel virtually undressed. Pontiac insists on calling the whole thing a “distinctive, tautly stretched exterior” that “express[es] the clean, athletic styling direction of Pontiac.” Yet not even the car’s aggressive five-spoke rims or deep front skirt and wide-set foglamps can rev up its looks. And speaking of forgettable, nowhere on this GTO will you find a “Pontiac” badge. Oops.
Oh, but that’s intentional, too. Pontiac feels “GTO” speaks for itself, that the name resonates as part of our cultural identity without elucidation. (Who over the age of 40 hasn’t dreamt of owning one?) And yet curiously—contradictorily, even—Pontiac aims to market the car to “young, affluent males” who don’t necessarily patronize the brand and have “no preconceived notions about GTO.”
“It’s important that this car has credentials, it’s for enthusiasts,” says Bob Kraut, marketing director for GTO. “We’re going to reach the people that ‘get it,’” though “over time we definitely want to attract the import-minded,” he says.
Confounding stuff, to be sure, but marketing-speak often is. What we do know is this: That despite the GTO’s uninspired skin, we “get it.” The reborn GTO is a driver’s car, through and through.
“TURN IT ON, WIND IT UP, BLOW IT OUT, GTO”
It doesn’t feel like any other car in the General’s North American lineup, not even the Corvette with which it shares a powertrain. Steering feel is fantastic, not quite razor-sharp like the Z06’s but totally natural-feeling, quick, crisp and responsive. Refreshing, really, given the vague, artificial-feeling systems found in other Pontiacs like the Grand Prix. This system uses a power-assisted variable-ratio rack-and-pinion setup, but thankfully not of the Magnasteer variety. The wheel itself has a nice heft, its leather-wrapped four-spoke shape providing good grip as the steering gets weighty at higher speeds.
On the twisty roads around General Motors’ Milford proving grounds, the GTO simply shines, its chassis almost unflappable over road imperfections and through aggressively driven curves. Its four-wheel independent suspension—MacPherson strut and progressive springs in front, multilinks with semi-trailing arms in back—hunkers down nicely in the turns and rides almost flat. Its 17-inch 225/50R BFGoodrich GForce TAs give a good deal of grip, too, and help the four-wheel disc brakes—11.7-inch vented fronts and 11.3-inch solid rears—and four-channel antilock braking system pull the car to straight stops with little drama.
Its superior body control feels particularly fine when hustled full-on through tighter combinations of turns. Believe us, no ’64 (or 1965-74, for that matter) could even come close to handling like this. The original GTO was known as an asphalt burner, the original muscle car, but in stock trim it did little well in modern terms except accelerate down a straight.
The optional Tremec close-ratio six-speed manual transmission does a great job keeping you in the chunky part of the engine’s powerband. Then again, with such a flat, fat torque curve peaking at 365 lb-ft at 4000 rpm, it’s not asking too much. The shifter itself, however, makes playing with the tranny all the more fun, with a pleasantly notchy action similar to BMW’s in feel. It even has that satisfying spring-back-to-center pop when disengaged. We never got it to hang up or miss a shift.
If none of that sounds like genuine GTO stuff, then perhaps this will: Underhood, and powering the rear wheels, sits an all-American V8 engine. Differences abound, however, most due to the passage of time—and the learnin’ it brings—more than anything. This engine uses all-aluminum construction and sequential-port fuel injection in place of iron and carburetors, requires 92-octane fuel over leaded gas, and emits but a fraction of the noxious fumes of the engine of old. At least the overhead valves are still there.
Displacing 346 cubic inches, the GTO’s 5.7-liter LS1 V8 nonetheless cranks out more power than the original car’s 389-cid (6.4-liter) engine, with 350 horses at 5200 rpm vs. the Tri-Power’s 348 hp at 4900 rpm. For the super geeky, that amounts to 61.78 hp/liter specific output compared to the ’64’s 54.59, even if today’s car loses out in the power-to-weight department. At 3725 pounds, the smaller ’04 model outweighs the original Pontiac Tempest LeMans GTO hardtop by 599 pounds.
Despite its increased heft, Pontiac estimates the six-speed GTO will run to 60 mph from a standstill in just 5.3 seconds and turn the quarter-mile in around 14 seconds at more than 100 mph. According to the Standard Catalog of American Cars, the ’64 was good for but a 6.6-second 0-to-60-mph time and the quarter-mile in 14.8 seconds.
With all its handling and straight-line prowess, the GTO’s ride never approaches the too-harsh feel of out-and-out sports cars. The car moves smoothly over the road, its taut suspension reading every nuance without bursting a kidney, and transmitting a decent amount of information about what’s going on underneath your seat. The suspension rebounds quick-ly off of bigger bumps, without upsetting the car but never feeling the least bit wallowy. And only a minimal amount of road noise makes its way into the cabin.
But at wide-open, the passenger compartment echoes with a deviously tuned exhaust note, growling out of a true dual exhaust channeled through siamesed twin pipes tucked under one corner of the rear bumper. That grunt is perhaps the most GTO-like aspect of this muscle car built for 21st century tastes.
SITTING PRETTY
Unlike its yawn-inducing exterior, the GTO’s interior speaks fluent sports coupe lingo, with a clean but sporty style punctuated by tastefully inspired splashes of color coordinated to the car’s paint. The color-keyed gauges and door inset panels work well, particularly when paired with matching leather seats. And attention to the details—like the contrasting stitching on the steering wheel, shifter and parking brake, the uncluttered layout of the controls and the machine-drilled aluminum pedals—imparts to the GTO a true sports car character.
A true sports car for four, no less. Pontiac calls the GTO a 2+2, but the rear seat offers plenty of leg- and headroom for real-sized adults. A relatively low H-point helps out to that end, though the rear access feature Pontiac is so proud of makes climbing in and out of the back seat a chore. Tilt the front seat forward, push a button and a servo powers the front seat forward; flip the seat back, and the same button reverses the movement—but it’s sooo slow. A standard manual lever would make the whole process much more tolerable.
GET YER GOAT
The GTO should start rolling into Pontiac showrooms across the country within the month, with all 18,000 annually produced units slated for the States. And if you think all this performance will come with a price, you’re right, but it’s not an outrageous one. Stickers should fall around $33,000, north of entry-level Bonneville territory but less than a fully dressed Bonneville SSEi.
GTO will get only one option, the six-speed, that will add $695 to the bottom line. Everything else you’d expect from a car of its class comes standard: traction control (but no stability control), 200-watt Blaupunkt stereo with six-disc in-dash CD changer and 10 speakers, tilt and telescoping steering wheel, keyless entry, leather interior, floor mats, etc. So far, Pontiac says early sales orders are running 50/50 between the six-speed and the standard four-speed automatic, though the automaker expects final breakdowns to shake out to around 35 percent to the manual.
Second coming or no, this goat’s got the goods.
2004 PONTIAC GTO
ON SALE: December
BASE PRICE: $33,695 (est.)
POWERTRAIN: 5.7-liter, 350-hp, 365-lb-ft V8; rwd, six-speed manual
CURB WEIGHT: 3725 pounds
0-60 MPH: 5.3 seconds (mfr.)
Autoweek
Premium Member
Oldster here at work owned two GTO's in the late 60's. Even he thinks they look UGLY! I saw one in January on display at the LA Auto SHow and I must agree, nothing to get excited about looks-wise.;)
BASE PRICE: $33,695
not for that car.
I doubt it will sell well after the first year.
yeah, sorry but nothing to spectacular going on here. Given pontiac's recent history w/ sportier cars, this one is doomed to fail from lack of sales. Pontiac is dying for something in its lineup that will shine, and I don't think this is even close to it.
I can't believe you guys are dogging the look of an old GTO :eek:
'66 '67 has to be one of the classiest looks ever.
Anyways, I got a recommendation for the genneral...drop the whole freakin Pontiac name and just bring over Holden with all its gold.
Jvtec said:
BASE PRICE: $33,695
not for that car.
im not too fond of the exterior...but man they went all out on the inside of this car..
but as far as sales..remember..this forum isnt exactly its sales target;)
Come on, guys. This thing will blow the doors off of anything else near it's price range. 350HP and RWD for $33K?? :eek:
You guys give thumbs up to a turd mini-van (Odd-i-see), then trash the GTO because it's a Pontiac. What kind of weirdos are you?
what up with the sig?
at any rate i like the old school GTO better then the new one it just looks like another grandam
True. 4 wheel Independant suspension, 350hp v8 with tq to match, nifty/luxurious interior, 6spd option, etc.... For its money, the only car that's actually faster is the Cobra, and this GTO has a rommier/better interior.
I think it's an excellent value. It'd make a complete joke of all the maxima's, G35's, TL's, 3 series, etc.... in terms of value and bang for your buck. What makes these other cars worth the 33-35k asking price and not the GTO? :confused:.
Discussion Starter #13
2004 Pontiac GTO
Base price/as equipped: $33,190 (manual); $33,495 (automatic)
Engine: 5.7-liter V-8, 350 hp/365 lb-ft
Drivetrain: Six-speed manual or four-speed automatic transmission, rear-wheel drive
Length x width x height: 189.8 x 72.5 x 54.9 in
Wheelbase: 109.8 in
Curb weight: 3761- 3774 lb
EPA (city/hwy): 17/29 mpg (manual); 16/21 mpg (automatic)
Safety equipment: Dual front airbags, anti-lock brakes
Major standard equipment: Air conditioning, power driver's seat, cruise control, AM/FM CD sound system, 17-inch alloy wheels
Warranty: Three years/36,000 miles
TCC
PRETTY NICE? I better not here anymore interior bashing on domestics.:p
That car looks dope from the ground up IMO. The exterior styling is lacking a little but it's still a steal at that price compared to the competition.
if i could afford the gto i would just save up a lil more an d get an 03 cobra
Having GM roots, I have to make one comment that I personally feel holds true for Pontiac:
Most of the people I talk to think that GTO is fine because of the power and RWD, along with a 6 speed, but they ALWAYS complain about the exterior details.
IMO, Pontiac kind of has a "look." Easily recognizable. Straying too far away from their traditional styling spawns such creatures as...
THE AZTEK da daaaaaaaa! <-- scary music
aaaaaaand
THE NEW SUNFIRE da da daaaaaaaa! <--more scary music
Everybody has their personal preference, but I think the GTO looks great and using a trademark look is like sales insurance....hehhe. God knows we wouldn't want a 350 HP Sunfire runnin round herr!
1 - 17 of 17 Posts
