1 - 20 of 28 Posts
2007 Infiniti G35 Sedan Pics *UPDATED with specs*
Pics leaked a day early. Suppose to be revealed at the NY Auto Show tomorrow. Credits go to da mayor of g35driver.com for the pics.
I like what I see, but glad it doesn't make my 06 G sedan look too dated. Will be updated with specs.
*UPDATE*
More info (from Nissan/Infiniti)...
At a Glance: 2007 Infiniti G35 Sedan
The all-new 2007 Infiniti G Sedan, which goes on sale in November 2006, is the second generation of Infiniti’s groundbreaking sport sedan. First introduced in 2002 as an alternative to the existing “machine-like” vehicles in class, everything about the new 2007 G is designed to create a more powerful driving sensation – from its rewarding performance and the sophisticated exterior, to the finely crafted interior and intuitive technology.
The new G’s exterior continues the original vibrant design theme with seductive, athletic styling that is clean, simple yet very distinctive. Key design elements include the sculpted grille blades, iconic headlights and taillights and the new, crisp character line that emphasizes the G’s aggressive rear-wheel drive appearance.
Inside, the all-new interior design is refined, inviting and offers a new level of modern warmth and hospitality. The G interior also offers unique features such as the white-and-violet Fine Vision gauge illumination and high-touch, textured aluminum-alloy trim with "Washi" (traditional Japanese handmade paper) patterning.
Available advanced technologies include RearView Monitor, a touch screen navigation system with available real-time traffic and the audiophile-quality Infiniti Studio on Wheels™ by Bose®, combining the industry’s first 3-way front door speaker array using 10-inch woofers with an audiophile quality head unit incorporating a 24-bit Burr Brown® Digital Audio Converter.
The heart of the G35 remains its advanced engine, platform and drivetrain, anchored by the “next generation” of the award-winning VQ-series 3.5-liter DOHC V6, now rated at an estimated 300-plus horsepower*. The standard V6 is mated to a choice of a 5-speed automatic transmission with manual shift mode and Downshift Rev Matching or close-ratio 6-speed manual transmission. Steering wheel-mounted solid magnesium paddle shifters are standard on the G35 Sport A/T model.
The G’s second generation FM (Front Mid-ship) platform features a 4-wheel independent suspension with lightweight aluminum components and improved body stiffness. The 2007 G35 is also offered with Infiniti “intelligent” all-wheel drive system.
Highlights of the 2007 Infiniti G35 Sedan include:
Body
Advanced Front Mid-ship (FM) platform (second generation)
An evolution of the original G35 design with a long, wave-like hood, pushed-back A-pillars and aggressive stance
Enhanced sense of dynamic surface tension and polished craftsmanship
Double-arch grille with sculpted grille blades, High Intensity Discharge (HID) bi-xenon headlights, integrated fog lights, L-shaped LED taillights
Unique front fascia and side sills on Sport models
Available Adaptive Front lighting System (AFS)
Available rear spoiler on Sport models
Lightweight aluminum hood, available heated outside mirrors
Available sliding glass sunroof with tilt and one-touch open/close feature
Eight available exterior colors, including four new colors
Engine and Driveline
New fourth generation VQ-series 24-valve 3.5-liter DOHC V6 producing an estimated 300-plus horsepower
New ram air dual intake, equal length exhaust manifold and dual exhaust system with laser-welded rear mufflers
Higher compression ratio (10.6: 1 versus previous 10.3:1), higher redline (7,500 rpm versus previous 6,600 rpm), new eCVTCS (electromagnetic variable exhaust cam timing), twin knock sensors, improved cooling and stiffer engine block structure
Refined electronically controlled 5-speed automatic transmission with Downshift Rev Matching and DS mode and ASC (Adaptive Shift Control), or close-ratio 6-speed manual transmission
Rear-wheel drive
Magnesium paddle shifters on Sport A/T model
Standard rear viscous limited-slip differential with Sport models (5AT and 6MT)
Front engine/rear-wheel drive or ATTESA E-TS™ all-wheel drive (G35x AWD model)
Suspension, Steering and Braking
Redesigned 4-wheel independent multi-link suspension with extensive use of lightweight aluminum components, front and rear stabilizer bars
Available sport-tuned suspension (Sport models)
New power-assisted vehicle-speed-sensitive rack-and-pinion steering
4-wheel power-assisted vented disc brakes, 4-wheel Anti-lock Braking System (ABS), Electronic Brake force Distribution (EBD) and Brake Assist (BA)
17-inch aluminum-alloy wheels with P225/55R17 V-rated tires
Available 18-inch aluminum-alloy wheels with 225/50R18 front and 245/45R18 rear tires (standard on Sport models)
Standard Vehicle Dynamic Control (VDC)
Standard Tire Pressure Monitor System (TPMS)
Interior Features
Driver-oriented interior styling with fine craftsmanship and modern warmth
Standard leather-appointed seating, available in Beige (except Sport models), Black or Gray
Unique "Washi"–pattern (traditional Japanese paper) aluminum-alloy trim on center console, instrument panel and doors
Standard 8-way power adjustable driver’s seat and 4-way power adjustable front passenger’s seat
Hand-stitched leather-wrapped steering wheel with steering wheel mounted audio and cruise control switches
Fine Vision gauges with white and violet illumination
Available wood trim on center console, instrument panel and doors
Standard Infiniti Intelligent Key with Push Button Ignition
Available Infiniti Studio on Wheels by Bose, combining the industry’s first 3-way front door speaker array using 10-inch woofers with an audiophile quality head unit incorporating a 24-bit Burr Brown® Digital Audio Converter
Standard audio system featuring in-dash CD changer with mp3 playback capability and 6 speakers
Leather-appointed and aluminum shifter lever
Available Infiniti Navigation System with available XM® NavTraffic™ real-time traffic information
Available Bluetooth® Hands-Free Phone System
Available RearView Monitor
Available sport-styled front seats with thigh extensions and power torso and thigh bolsters
Available sport-styled steering wheel and aluminum pedals
Available satellite radio with choice of XM® or Sirius™ providers
Infiniti signature analog clock
Digital automatic temperature control with standard micro filtration and rear heater vents, available dual HVAC control with available rear vents
Available Intelligent Cruise Control (ICC)
Safety and Security
Standard Advanced Air Bag System with dual-stage front supplemental air bags with seat belt sensors and occupant classification sensor
Standard front-seat and front and rear curtain side-impact supplemental air bags
3-point ALR/ELR seat belts (driver’s seat ELR only)
Front seat belt adjustable upper anchors with pretensioners and load limiters
Front seat Active Head Restraints
Zone Body construction with energy-dispersing side structure
Engine mount breakaway design with breakaway driveshaft
Retracting brake pedal to help reduce lower leg injuries in severe crash
LATCH (Lower Anchors and Tether for CHildren) child seat anchorage system
Models and Manufacturing
Available in five models: G35, G35 Journey, G35x AWD, G35 Sport and G35 Sport 6MT
Assembled by Nissan Motor Co., Ltd. In Tochigi, Japan
* All horsepower ratings are per SAE J1349 (AUG 2004)
damn look at that redline. its pretty much the same as rsx-S, must be performance oriented....or not idk what i'm talking about. new design looks real good. i like it alot. holds true to previous G35 look. very nice IMO. love the center console too. very simple yet classy. nice gauges cluster.
wow, i really dont like it. the front looks really awkward. i dont like the center console either. cannot stand analog clocks in cars...lets just divert the drivers attention from the road even further. :rolleyes .
damn...even the soaring gasoline prices are affecting big time automakers. tsk tsk... :noo
thank god for that digital clock on the monitor eh? :rolleyes
overall, i think it looks great. i hope they did better on the interior though. the current gen G35 looks and feels very cheap inside for this caliper of a car. my 04 accord coupe interior feels more lush and luxurious than it.
It's alright... I agree about the redline though, quite intriguing.
don't you know the analog clock is Infiniti's signature? I am loving the lines. First thing I though was muscle when I saw the pics. And 7500rpm redline? wow. From what I hear, the new G is supposed to make at LEAST 320-340hp for the base sedan 6spd. Loving it. Infiniti has made huge leap in interior quality in the past few years.
Midi_Amp said:
The rear end is yummy... Aside from the side mirror which looks cheap, the car is very nice. It sweats lux and power, especially from the quarter rear view. Does this car use VQ35?
Nissan is never going to let the VQ go mang. Its been going strong for the past 12 years and still making it to the top of the best V-6 list ie. ward's auto. Holds true to the current G35/Skyline theme and the G Coupe concept. Look out Bimmer, I believe Nissan is aiming for that 1 spot again.
Looks like they finally smartened up and are using a bi-xenon setup now. The old setup was just plain strange. The low beam xenons were in the top reflector, and the bottom one served as BOTH high beams and fog lights.
And that cluster looks way familiar (who in here has an 04/05 TL?).
I love the current G35...so I'm sure this one won't disappoint me either.
  • Like
Reactions: Roro
glad to see that yellowish orange theme go away with the gauge cluster, damn near impossible to see the gauges when driving west during a sunset
yeah, makes the analog even more useless eh?
thats fine if infinity wants the 'signature' of their automobiles to be a useless analog clock, i just think its a waste of space.
1 - 20 of 28 Posts
