where the transmission speed sensor is located
There is generally one vehicle speed sensor, which is usually installed in the drive axle housing or transmission housing. The signal wire of the vehicle speed sensor is usually installed in a shielded jacket. This is to eliminate the electromagnetic and radio frequency generated by the high-voltage electric live wire and the car phone or other electronic equipment. Interference, which is used to ensure that electronic communications are not interrupted to prevent poor drivability or other problems.
Automotive lighting Electrical wiring Cable Gas Electrical supply
