$50.00 for 280 watt Pioneer GM-X354 4 channel amplifier
mint condition: used, not refurbished/reconditioned. 50$. pm me.
Specs:
- PWM MOSFET Power Supply
- Continuous Power (14.4V): 35Wx4 (4ohm), 40Wx4 (2ohm), 70Wx2 (4ohm)
- Max Power (14.4V): 70Wx4 (4ohm), 140Wx2 (4ohm)
- Frequency Response: 10Hz - 50kHz (0,-1dB)
- Total Harmonic Distortion: 0.008% (1kHz, 4ohm)
- Signal-to-Noise Ratio: 100dB (IHF-A)
- Dimensions: 11" x 2-5/16" x 9-5/16"
Features:
- Bridgeable 2/3/4 Channel Capability
- Balanced Isolator Input Circuit
- Screw-Type Power/Ground Terminals
- Screw-Type Speaker Terminals
- RCA Inputs (4 Channel)
- RCA Outputs (Full Range)
- Hi-Volt Input Level Control (400mV-6.5V)
- Molex Type Speaker Level Inputs (4 Channel)
- Selectable Crossover: 80Hz, -12dB/oct. LPF or 80Hz, -12dB/oct. HPF (A,B Ch.)
