Discussion Starter #2
86 honda accord a20a turbo build
exhaust replace APR head studs new performance braking parts engine oil cooler kit more pictures to come up intercooler installation intercooler piping adjustable fuel pressure regulator installed
Pictures of front intercooler mounted intercooler pipe Massimo turbo header order from the Netherlands intercooler piping cut measured installed blow off valve
Discussion Starter #4
More parts silicone couplers to fit blow off valve and turbo here's a header I got with a custom flage made but I decided to go with the mosselman turbo header because there's enough modification and custom work that has to be done. all gauges purchased & wired I'm down to only two more parts which is the new clutch kit set and the AMC piggyback her brain
