i am putting n the mottor
oh, well then. do it yourself.
If you are takeing out the motor you'll most likely take out the whole engine/tranny as one unit, its much easier than just pulling the motor in case you had not figured that out.
To do this you have to remove the CV shafts from the transmission and front hubs to even pull the damn thing out, so just pull them out, throw your busted shafts away, and put in new ones.
A good way to check to see if they are bad right now, is go under your car and check the rubber boots on them. If they are torn, this most likely indicates that they are bad. A torn boot lets crap get all up inside the CV joints and wreck them up.
Its been a while since I've had to buy new CV shafts, but Im guessing you could probably get them new from NAPA or something for 200 bucks or so.
Also, since you have to tear your front suspension apart to do all of this, check your ball joints and suspension bushings for signs of wear too, these could all cause problems in your front end too.
