i have a 91 accord and it idles real rough, it hesitates at the beginneing of acceleration and my sports light blinks. i told that it could be the egr valve. anyone know wht it could be. also when i break, whether at low speed or high speed, my steering wheel shakes a little and my car pulls to the right. i am not sure if it is just my front end but there is a clunking noise when i turn and a clicking noise when i turn sharp. any help will be great.
clunking or clicking when turning = cv joints gone bad = new axles
Pulling when braking is normally equal = to a seized caliper
The bumps you feel when braking are your warped rotors = need to turn them
The rough idle could be a number of things and its always good to start with a tune up. I have seen rough idles caused by a number of things including reusing a valve cover gasket which will leak around the spark plugs over time. With that said its probably worth you time to do a complete tune-up first.
Its alot easier to bite repair cost if you do preventative maintenance over time vs waiting till everything goes and worrying about several hundred dollars at once.
just my 2 cents
