Well, i figured out why my sony cdx-m610 head unit kept on losing my settings and it was because the idiots that put in my head unit did not connect the 12 volt constant and they even went as far as to clip it of the head unit harness. So now i need to do some carefull work and get a wire back on it. My question is where in the area of the stereo location can i tap into for a 12 volt constant? or can i just run the 12 volt constant wire straight to the battery?
yeah man ...with adapter it was really easy...all you need is right there...
Cutting your factory wire harness and not using a Metra adapter is gonna hurt you in the long run.
Plus the Metra adapter has every wire labeled what it is.
Check out my sounddomain members page.
