hey guys,can you help me!i have a 94 accord 2dr coupe non v-tec,have header,and a stage 1 delta cam.when driving it will hit the rev limiter at 4,500 rpm.is this normal?checked timing-crank at tdc and cam lines up with marks on the head.drives ok,no dtc's throttle cable adjusted to spec,distributor set in middle of adjustment.ngk plugs,oem distributor,cap and rotor.oem wires.
