'94 prelude speakers
1141 Views 6 Replies 5 Participants Last post by  racerpunkX
i just bought a 1994 prelude vtech last week and i want to replace the speakers. I can't get the door panels off though, can anyone help? I also wanted to put 6x9's in the rear deck. What do i have to do to fit them since the stock speakers are 6 1/2's?
I would assume that the basic layout is the same as the JDM versions, mine is a 92 JDM VTEC and had 5 or 5 1/4 inch rounds front and back. The front are no problem. I replaced them with a component kit (main speaker, crossover and tweater), the speakers kitted directly into place with any mods.
The rears are trickier because the depth of the hole they go in is not good because of the boot (trunk) springs. I had to use cheaper slimmer speakers. It should not matter going that because the best of the sound should be upfront anyway.
To remove the door panel you need to pull of the triangular plastic trim on the inside of the mirror. There is a screw in the buttom of the plastic tray/holder in the door arm and a screw under it. Another under the door open lever. You have to carefully unpop the whole door card and slide it up.
Nick
Since he helped you out with the technical info.. I'ma help you out with the correct spelling of VTEC so nobody goes off on you later. ;)
Thanks for that, I should read what I type before posting.
Nick
Or you could buy those 6 1/2 inch speaker depth risers or whatever they are called. I am not sure of the technical name but I am sure someone here knows what I am talking about. As a matter of fact I am looking for some right now, if you guys know where to get them le tme know!!
Nick
No problem. :)
I'd just get....
Just put new 6 1/2s in, putting in 6x9s is looking for a ton of trouble, cutting new holes and shit....I wouldn't do it. Just get like an 8 or 10 inch sub for the trunk if you want that sound.
