recently, my cars been acting up. its slowly been dying down. it'll crank and crank but it seems as if its getting no spark. within the past 2 weeks its gradually gotten worse and worse to the point where it doesnt want to start anymore. its fuel injected, but say i crank it to the point where it sputters, i can give it gas and it'll fire up. but a few blocks down the road itll want to stall. if the motors kind-of warm, itll start up a little easier, but if i let it sit over night, its a bitch to get running, so i've been using another car. if theres anyone that would know any thing about this situation, the help is appreciated.
thanks.
-steve
Sounds like it could use a tune up. But from the information you gave it's really hard to tell, and would be easier if we could see it.
Could be plugs, wires, distributor/rotor, coil, main relay...
If none of those things have been replaced in a while, or ever, I would start there.
I don't know your situation that well, but I would suggest that because it's 11 years old I would begin to start paying careful attention to it. Keep a log of everything you do to it and at what mileage you've done it at, and write down at what mileage that it needs to be done again. A typical log entry could be:
3/15/2006 (123,456 miles): Changed the oil, using Mobil 1 5w30 and a K&N oil filter. Needs to be changed again at 126,956 miles.
i keep logs of that. such as changed plugs, flushed radiator, oil, filters..
i take care of it.. this just happened out of nowhere.
i recently had a viper 791xv installed, some people have had similar problems with the alarm because of remote start, but idk.. they havent said anything about it.
Have you checked your fuel filter lately. Sounds like it could be stopped up.
thanks.
-steve
sounds to me like a bad coolant temp sensor .or a bad iAT
