1996 honda accord ex
I changed the rotors and brake pads to slotted and drilled rotors and yellowstuff brakes but for some reason im still getting vibrations during braking. the steering wheel and wholefront of the car vibrates.
i have checked the torque on the brake caliper mounting bolts, the caliper mount to knuckle bolts, and the hub to rotor bolts. my only other guess is the 4 rear knuckle to hub bolts but if the only cause of this is lateral runout or warped rotors then i don't wanna take apart the suspension to check bolts that may not even be messed up
ive taken the steering knuckles off several times now due to having to change drive axles and rotors. and then later changing the transmission and lower ball joints
any ideas?
any ideas?
