I can't find anything on this with search Basically I want to replace a stock engine with the same one. No H22 swap just the same engine it came iwth. Is there any type of data sheets on instructions online for it? Or even instructions on engine removal for the 6th gen accord. All I can find are the 5th gen ones.
Thanks
Super Ban-Finger Mod
it wouldn't be any different.
disconnect and remove battery, drain coolant, drain transmission fluid, remove axles, disconnect wire harness, disconnect clutch slave cylinder, disconnect fuel line, unbolt motor mounts, remove engine/transmission.
