I have a 98 2.5tl ,the blower motor went out.I replaced the motor and then it would not come on I jumpered the motor lead to a battery and the blower came on.I then took out ,what I believe to be the speed controller.Its a heatsink looking thing with a large transistor and a disc shaped ,resistor/thermistor?,it is labled 475k 25v.I jumpered the connector across 2 of the 3 connections and now have high speed only.Thermistor,if thats what it is reads open on my multimeter.Also I removed the 134a from the ac system when i replaced the blower.After doing the install I cannot get the air to blow thru just defrost or just the feet the flapper control seems to not be working.Could the ac system being empty have anything to do with this?
