hey well if anyone here is good with electrical problems with my accord please help me! Well first of all from the drivers side I can't lower or raise from the right side only the back drivers side but I can lower them from each door! And now when I lower the lock the lock from the driver side it should lock all the doors but I doesn't, I now have to lock/unlock every door manually!
Does anybody know what could have happened?
Oh by the way it happened once already but it just somehow fixed itself!
Any help would be very helpful!
Yeah I checked the ones that had to do with the power window and they are ok but what's weird is that I can lower the window from the passenger door but I can't control the passenger window from the driver door? If it was a fuse causing this will this also make the door lock switch not too work? And let's say it is a fuse what fuse should I be looking for?
Thanks for any comments in advance!
Discussion Starter · #5 ·
Ok well after spending some time researching all over the web i found this... Honda Power Window Woes and to tell you the truth i though it was bull because it seemed so easy and i though it wasnt going to work but it actually did.
Now my question is... if i disconnected the battery overnight would that reset it too? Because I disconnect it last night and connect it this morning but nothing changed and then i decided to try this and it worked.
Well thanks again for your input.
