Ok. Here is the first batch of updates
Looks like I took these pics back in Feb. Wow... I really got lazy with the updates... Anyways...
I picked up a yellow box a few months back. The yellow box is a speedo recalibrator so it will let your adjust the vss signal passed from the vss to the ecu and to the speedometer. It has dip switches so that you can set the adjustment factor to correct for the difference in tire size between the donor car (rsx-s) and your car (98ex in my case).
I believe the adjustment was roughly 8%. Doesn't sound like much, but having an accurate speedo is a good thing.
You can wire the yellow box anywhere you want. It comes with a molex connector (like you have inside a desktop pc), with 4 wires. The 4 wires are :
* power
* ground
* signal in
* signal out
So I went the lazy route and wired the power and ground into the ignition and ground wires over by the steering wheel. I had already tapped these for my oil pressure and egt gauges. Next I spliced into the k20 swap harness to intercept the vss signal, pass it to the signal in on the yellow box and the yellow box signal out goes back to the harness.
I did not want to splice into the engine harness to intercept the vss before the ecu. I did not know if lying to the ecu would cause any issues.
All of these pictures are under the passenger side dash.
Locating the wire to splice into.
