So I've been a little lazy. Its been hot, a lot of things going on in the evenings, so the car has been a bit neglected. Really should of had it finished by now. But here we go
I bought a piece-o-crap harness from a 96cx just for connectors and brackets. This way I could sell my stock ex harness.
I needed this bracket from the old harness to put on the k-series harness. This allows the harness to pass into the cabin and close the hole just like the original one.
I got the fuel setup finished. I used the karcepts fpr bracket but instead of using the suggested location by the water neck on the head. I removed the stud that was on the airbox support and drilled a hole there and put a nut on the backside of it and secured it there. This way it is still relatively close to the fuel rail but plenty of room around it.
Hybrid racing harness. I'm a little confused by a few things on the harness. It looks simple enough, but not sure why they didn't reuse more of the stock wiring in the chassis. For example, don't see why they don't tap into the stock harness for the secondary o2 sensor. Would also be nice to have the evap vent shut wired in, and I'm not sure they have cruise wired in. I'll be a little annoyed if I have to run another wire for cruise.
Hondata k-pro
Needed a new set of rear brake pads. I had about 2mm left on the rears before I hit the wear indicator. These are the
Carbotech Bobcats. I've been really happy with these over the past few years.
Radiator Hose Cut. This was a stock lower hose for an integra. The portion on the right will be my new lower hose.
Power Steering High Pressure Line. I straightened out the hardline. Figured it would be easier this way to bend into the shape that I need.
The front suspension is put back together. I used new tie rod ends. No point in reusing the ones from the salvage yard or my stockers which are nearly 10yrs old. Had to use a pickle fork and a 3lb sledge hammer to get the originals out of the knuckles... That was a pain in the butt...
The rear suspension is put back together. Took a little work getting things into place with the new bushings. Much firmer than the old beat up originals.
