I got into an accident recently and cracked my ac center console and since i have to replace it, i was wondering if i could use the 99-00 one since all the connections in the back look very similar except they go vertical on the left side instead of horizontal on the bottom....i called honda and they didnt know dick as usual, could someone help me out?....
the car in your sig is a 5th gen...unless you're talkin' about another civic you have.
but i think the wiring should be the same, the only problem i would think of is that the dimension might not be interchangeable. meaning the actual bezel might not fit...
ghost
I have a 96...this screenname is my friends, that blue hatch is his...i was kinda thinkin the same thing bout the dimensions, but i think its damn close...thanx for postin...ne other posts will be appreciated...
igo4bmx said:
wiring is totally different
96-98 uses mechanical cables and shit to move the parts...
99-00 use electronic knobs and buttons to power things
well shit, there you go, haha...
ghost
