Setting the TPS
You have to use a voltmeter to set the Throttle Position Sensor, the TPS sends a voltage signal to the computer to tell it how far open the throttle is. If it isn't set properly then the TPS will send the wrong voltage to the ECU when the throttle is closed, creating a bad idle.
To fix this you need it sending the right voltage when the throttle is closed.
There will be three wires going to the TPS.
The Green one is a ground
The yellow one is constant 5V
The red one fluctuates between 0 and 5V depending on how open or closed the throttle is.
You need to connect the voltmeter to the ground wire and the other one to the fluctuating wire by exposing some of the wires. Loosen the screws and shift the TPS around until it gives a voltage of 0.45 Volts when the throttle is CLOSED. It doesn't matter what it says at open throttle.
The harness must be plugged into the TPS which must be attached to the TB, therefore it is much easier to do this with the TB removed.
If you need to adjust the TPS, loosen the two small bolts holding it on and turn it either way until it gives the correct voltage. Some TPS's are attached with rivets instead, in this case you will need to use a Dremel tool or similar to remove it. If there are rivets holding it it is most likely still set from the factory and will not need setting.
If you need to adjust you idle, turn the idle adjustment screw with a flat blade screwdriver. If the screw is loose you may need some silicon to hold it still like I have.
After doing this I noticed my idle wasn't quite right. The Honda manual I have says 0.45V but when I measure my stock TPS which was still set from the factory it was 0.32V so that is what I have mine set to. Once I had it set to 0.32 the idle was fine.
If you know someone with the same car you could measure their closed throttle voltage to see what their car has but try setting to 0.45V first. I suggest you measure your stock TPS setting before moving it so you can at least revert back to the original setting. There may be other Hondas which have settings other than 0.45 volts, you can ask someone on
www.**********.com who may have the same car.
