I have a 99 SI that doesnt have much heat in the winter. In temps of 32 degrees and below it takes the engine quite a long time for the engine temp guage to rise and maybe it rises by 2 or 3 bars only. Heat output is dismal at best. In the summer, it doesnt not overheat at all even with the AC running and outside temps are over 95 degrees. If I let it idle, the temp guage will rise a bit higher but once the car starts moving the guage drops down to the 2nd bar to near bottom of the engine temp guage. Is this a symptom of a failed or stuck open thermostat? What is the proper thermostat range of the b16? I have seen various replacement thermostats ranging from 170 degree F to 198 degrees F. Thanks
