The buttons for the A/C and the recirc. mode no longer have a back light to them.. The rear defrost does? They do light when you engage them with the light bar but the symbol does not light?? A/C button turns on compresor still and recirc work?? :eek:
How do I remove the button face to get at the bulbs or the center cluster. Where the radio, HVAC, and buttons are?? How hard is it to remove, and how much are the Honda parts?
You first need to remove your center dash pannel. It's held in with clips. A little tug, and be carefull. After that you'll see there are four screws holding that switch pannel in place... but you dont need to remove them. you should see some round button like things on the back of the switch pannel. They have a notch in them, like a flathead screw. Simply un-screw. The factory part # for the bulbs is : 79609-S04-A01 . They are about $3-$4 USD.
Good luck. :clap
