a couple of things
742 Views 4 Replies 4 Participants Last post by  PSIKOTICsi
i have a crx with a zc moter,new ignition,exaust,etc and i was wondering a couple of things. first off, can anyone talk to me about getting a turbo chager. second, a zc transmition would help me out alot,but where do i look. last off, what kind of clutch could work well with my car.
Welcome to the board!
Drag II turbo for zc $3K from impotparts.com
Clutch Masters stage 1 or 2 depending on hp you are going to be looking at.
The zc tranny w/ LSD is pretty rare from what I've been told and I could not even tell you where to start.
---- their are some really good aftermarket LSD's that you could use. (Quaife, KAAZ, Phantom Grip)
turbo
what about taking the bolt on turbo from a old eclipse and putting it on my car, a couple people said it would work
Re: turbo
www.homemadeturbo.com
..or if you're looking for a cheap kit, go w/ the 92-95 civic greddy kit....its almost a bolt on w/ little modification to the kit...
doing a cheap kit yourself would be good...thats if you have experience with turbos and such. if you have experience then you could put one together for roughly about 1500 bucks...im doing this soon for people in my crew using a custom turbo manifold and a t3 turbo.you could bolt on a 92-95 civic greddy turbo kit(minor porting of the turbo manifold required so it matches up, a drag turbo kit(this is a specific application made for a crx with a dohc zc motor, or you could go custom. you should think about how much power you want to make in the long because that will help you decide on what setup to aim for.
