OK, this topic is obviously just a mad idea. It's very unlikely it would ever get built, but lets just discuss it anyway.
Here's what I had in mind. Start with a CRX, and yank the motor and transmission out. Build a custom subframe mount for the Suzuki Hayabusa motor, and then build a custom aluminum differential. There would be a short chain drive from the Busa motor to the diff. Custom alxes would then mate to the differential. Cost would be $3000 - $5000.
The benefit is that you would get this power curve and a crazy 11,000 redline. Plus the motorcycle engine/trans/diff would weigh about 200-250 LBS.
The differential and mounting would look similar to these pictures.
What does a CRX without motor and trans weigh? What would it weigh with manual windows/locks, and no power steering or A/C?
Would it be fun to drive? Hell yeah! Benefits would be a lighter overall weight. The car would have better weight distribution, as there would be less front weight. Obviously there is more power, and a crazy redline. There would also be the benefit of a 6 speed transmission, and an easily adjustable final drive ratio. (Sprockets are easy to change. The rear can be made in two pieces.) It should also get better gas mileage.
So what do you think?
