Im gonna look really stupid if your being sarcastic, what your asking is just like asking how long would my engine last with very little engine oil, well is it really good for it? and how would anybody really specifically know?pushVTEC said:Just a simple question? adn we are talking about transmission fluid... so why not ask a tranny fluid related question?
Its never good to run your car when it's low on any required fluid. "How long will it last if its low?" That I can't answer, but it will make it wear out much faster, and it could even lock up.pushVTEC said:Jesus christ, lets all flip out about a little question. If it's so dumb and obvious why don't u answer it and stop being asses about it?
Using synthetic oil in your ride is the single best thing you can do for its longevity. In other words, when you use synthetic oil, basically all wear ceases. Mobil 1 ran a BMW on rollers for 1,000,000 miles, took the engine apart and there was practically zero wear. I think one rod bearing was slightly out of spec.kommon_sense said:What is the advantage of using the redline tranny fluids?
I just use a funnel with a long flex hose. It's made for pouring oil into automatic transmissions. Or, you could use a pump and do it from underneath the car; like the ones they use for pumping gear lube into differentials. To me, the funnel is fastest and cleaner...B16a2vtec95 said:hey BDC to refill the mtf i heard you have to use so kind of hose to put it in? is that correct? how would i do it and where would i get the tube if it is correct?
GL-5 gears oils, which are required in most hypoid differentials, are NOT made to be used in synchromesh transmissions and transaxles because the chemicals used to provide the extreme pressure protection can be corrosive to synchronizers, which are commonly made of brass or bronze. GL-5 gear oil will eat your Honda tranny from the inside out, starting with the synchros!CivicSiBeast said:...hey BDC, whats wrong with GL5? Thats all they had at Kragan Autoparts.
$4.43/qt.asianpride559 said:how much are the oem honda tranny fluids?
If you are just checking it, like during a [motor] oil change, fluid should flow out of the 'fill' hole as soon as you remove the plug. If it doesn't, stick your 'pinky' in there. It should come out drenched in oil. If it doesn't, you definitely need to add oil.civic type r said:BDC: when changing transmission fluid, (my 92 civic h/b dx), i believe you are supposed to have the car on level ground. when checking the level, level ground also. how were u able to add the fluid in your tranny with it level? or i mean, did u have a lift? cause i know if the car is at an angle, the fill bolt reading will be off..thanks !
is that other stuff that much better? i do notice that now in colder weather my tranny isnt that smooth. its clunky but as long as it dont grind. ill drop some of that honda fluid in and see if it makes it as smooth as a new car.BlackDeuceCoupe said:$4.43/qt.
http://www.manhonda.com/ap/index.cfm?level=23&PG=0&CFID=1143860&CFTOKEN=53549788
Good lube, like Red Line MTL/MT-90 or Neo 7W is less than double that price. IMHO, this is the wrong time to get chincy. You're talking 8 bones vs. 16 for the best synthetic oil in the world. It's false-economy, if you ask me...
Yes, it IS that much better!asianpride559 said:is that other stuff that much better?...
the dealer carrys redline now? which redline should i get if i dont end up getting the Honda one? dont know why your car brand new had problems right off lot. mine dont have the reverse problem but i miss that feeling of that perfectly smooth shiftingBlackDeuceCoupe said:Yes, it IS that much better!
I bought my CiViC new. Right off 'the showroom', it was practically impossible to get into reverse. Worse yet, it would pop out of reverse with a BANG. I was told this was normal, and to give it a few miles. I did and it got worse.
At 9,000 miles I noticed the shifting was getting very 'notchy' for lack of a better word. Out of desperation and exasperation, I decided to change the tranny fluid and see if that would help. I did a LOT of research, and found out Red Line MTL was what a lot of racers were using. As a matter of fact, I had to buy it at a racing supply house; nobody else carried it.
Since then, my Honda dealer, Showcase Honda in Phoenix, has started carrying Red Line MTL and Neo 7W tranny oil in their parts department. This should lay to rest any concerns ppl have as to whether it these synthetic tranny oils will hurt your Honda transaxle and/or affect your warranty.
To make a long story short, I switched to Red Line MTL and ALL my shifting problems went away. My only concern was how 'thin' the oil was. So, in the summer months, I decided to use Red Line MT-90. I doubt if this makes any difference - it just makes ME feel better.
Bottom line is: I have almost 70,000 miles on my ride, and it shifts better now than it did when I drove it off 'the showroom.' The oil always comes out crystal clear when I change it; no sign of metal particles in it. This sh!t is the bomb!
