Hi guys!
Got a really weird problem that is quite scary... :-(
Going to work thismorning and coming off the motorway put my foot on the brake very lightly and the ABS kicked in (Very dry and warm day) and i couldnt stop... then the abs light came on on the dash and i was able to stop. Turned the car off to reset and then braked very lightly again and the same thing happened.
checked the fluid level and it is just above the min so i dont think is the problem.. After checking the fluid i only had about 5 mins left to drive to get to work and it didnt happen the rest of the way.
Any ideas on what could cause this as its very scary not being able to stop :wow
Cheers guys
Steve
Try bleeding your brakes and adding fluid. Low brake fluid can cause what happen to you. It happen to me once in my SRT. It hasn't happen since I have been keeping my brake fluid levels up.
