When I'm on the interstate and get over 85mph my ABS light on the dash goes on. Anyone know why? I'm hoping a sensor is just loose and there's a screw to tighten or something simple, but nothing's ever simple.
Hey, yeah TSM ur right... I own a 92 accord exr and had a brake fluid problem and everytime it was running low the ABS light and another came on...DId some research and i found it was indeed my fluid then i just replaced the loose cap and im set...
And MarkyH, if its happening only after 85 it may at most likely be ur brake fluid as you could be experiencing the same problem i had as mine came on after 60 km/h or when i revved the shit outta the motor....So all in all, i guess check ur sensors, wiring, and then if not replace the brake fluid cap or check if its low or leaking... :byye
