Hey newbie here just droppin by to say wassup to all the regulars. And I also need some of your wisdom. I have a 98 V-6 coupe. My ABS is acting up periodically. The light comes on from time to time. Usually during hot weather or when I 've driven it for a while. The car has about 76,0000 miles on it with the OEM tires. Could it be acting up cuz the wear on the tires? Or could a under or over inflated tires cause the ABS sensors to malfunction?
I'm thinkin in the back of my mind it's time to get new tires, if so which brand set of tires should I get?
I have herd of a simular problem on other cars. But i dont think the light will awalys comes on when it happens. Occausionaly the abs system will do a system check that could cause the light to come on and when you stop it could feel a bit jerky. YOu might want to describe the problem a bit more.
That's it my prob is exactly how you described. When it does go off my brakes occasionally jerks at slow stops.
