I want aircon, What do I need for it? I have a 95 civic with a gsr motor? I heard I need a del sol ac bracket? Where can I get one? Websites?
any b-series braket should work you'll also need to modify the hoses that go from the condensor to the compressor cause they sit dif on a d series then they do on the B, ive been meaning to do mine and thats what needs to be done
my gf's civic has a b18c1 and the shop used a del sol bracket and that was it. everything else in teh a/c system is stock civic parts.
then they just twisted the hoses around
well it appears to be identical to the system as far as how hoses are run in my civic...so i dunno....nothing was twisted when i had to replace teh condenser fan.
bracket
if you use a delsol vtec braket it bolts up like stock, because everything is lined up just like a delsol vtec. same engine bay + b series engine + same a/c system.
