1 - 17 of 17 Posts
i have some 18inch ADR rims.... i need tires for them.. tirerack.com says 215/40/18 would be the best.... but i want 225/40/zr18 for mine.. BUT WILL THEY RUB???
no coilovers, no shocks = stock height
no camberkit
would they?? without rubbing
thanks honda guys
not if you do it right. the outer diameter stays the same. I'm pretty much exactly on with the 225/40/18s I have, verified by GPS to within 1mph
:clap I have been looking for this info thanks a LOT :clap
go on yahoo and type in "tire calculator"
put in the stock tire specs and the tire specs that you want and it will tell you the width/diameter/ mph differences
I went with the recommended tire size +5 for the middle number to get extra side wall and fill the wheel well a little more. Worked out great. :hug
Ok how about tire wear on the 215/40r/18s. is the wear the same as stock tire size( 45,000 to 50,000mi with comparable mfgr) or is it less. a buddy of mine said he got 35,000 miles on a set of eagles. which seems low. please give imput..
that's more of a function of which tire you get. some last longer than others. The low profile tires tend to be more of a performance tire so you get less wear out of it. But not out of characteristic as if you went with the stock tire size in the same/similar model of tire.
1 - 17 of 17 Posts
