My friend is selling an aem ems for $300 in good conditions. But is for 96 to 99 integras. My integra is 2000... There’s any way that I can install it into my car?? Any special wires to buy or something?? Thanks...
call aem... you should be able to use it with an obd2b->obd2a conversion harness if needed.
do not attempt to plug that box into our existing harness you will fry it the second you turn the key on you will need a conversion harness from obd2b to obd2a the harness is like 100 bucks i just went through this same dilema with frying an ecu luckily they warrantied it
Discussion Starter · #6 ·
thanks for the warning !!! :clap :clap so is obd2b to obd2a...... ok ..
yes it will work if you get that harness
