White98LS said:The Icebox has great throttle response (short tube) and cold air benefits... all you miss out on is the look/sound of a typical open intake.
Most of the SRI's are virtually the same. I guess just go for AEM or whatever, really doesn't matter much. Injen is actually pretty good but I think appearance-wise they look kinda shitty.
you mean the way it bottlenecks? wouldn't that be good velocity stack considering you drive a hi revving motor? i don't know, i could be wrong.GSRGreenSleeper said:The bypass directions said to cut it kinda close to the throttle body. It would be a really short ram system, but not as short as the Neuspeed P-Flow. Plus, I don't like the way the AEM mates up to the throttle body..... it's hard to explain.
I have enough money right now, at the beginning of every semester i get a loan check. I set aside a piece of mioney for mods......WhiteTegRacer said:y spend sooo much money on intake? if your looking for a short ram, just take off the too of your stock air box and run it with a k&n filter, you'll have both a short ram with heat shield.![]()
imma poor person, i find ways to do good DiY
