I am throwing in a 14b turbo, but I am not sure what ems to use. Should I go with Hondata, and if so which one? Aem? Neither Aem nor Hondata seem to explain which one belongs in my 90 si hatch with a d16a6 engine.
Technically.. neither system was designed for use in a 4th gen...
BUT... the Hondata is going to be the one to 'pursue' if you 'need' that..Call them up and explain what you are doing.. Hondata is now doing 're-programming' instead of their 'piggy-back' systems for the stage 1 upgrade but I am sure that they would have 'some type' of system you could use.
What type of boost are you gonna run.. that you 'need' an engine management?
Hondata wrote back saying that I have an OBD0 and I need to convert it to an OBD1. And if I convert it, I can use either the s100 or s200 setup.
They said:
"It involves wiring, sensors, distributor and ecu. You may want to consider Zdyne."
Hondata Inc.
386 Beech Ave
Unit B-2
Torrance, CA 90501
310.782.8278
310.782.6383 FAX http://www.hondata.com
Related Threads
Honda and Acura Car Forums
4.2M posts
170K members
Since 2002
