Hi i have a 95 civic hatch Vti b16a convertion. I recently bought this car and was told that the air con didnt work, but that it did previously and stopped working one day. The whole unit doesnt even power on. If it was blowing but not cold air that would be easier. Could it be the air con fuse? And if i check that and everything seems fine what else could it be? Also when making a b16a convertion does that stop the air con working?
no a b16 swap shouldnt affect the ac you might want to check the stepper motor and see if its opening other wise maybe a fuse or a stray wire which you would have to home out(sp?)
I think you may have to change the entire air con unit since everything doesn't even turn on. Have you tried bringing it to Honda for car servicing? Maybe they could help you with this issue. Or if you would want to try servicing the air con yourself I read some articles on SGHomeNeeds that definitely helped save me some money from bringing my air con to service.
if you are looking at replacing your car's air con unit perhaps you would like to render this company's services? my friend who sells secondhand cars recommend this company for installing air conditioners!
If you would like to do aircon chemical wash you can find them too!
