1 - 12 of 12 Posts
im not that knowledgeable when it comes to tires
so i figured id ask for some help. The tires call for 44psi
but for some reason, when it has that much air put in, the
tires still look really low. should i just add more air until it looks
full or will that harm the tires? thanks
thanks, i just thought maybe it was rather low and i
wanted to get the right air amount so i can get the
best handling/gas mileage i can
Discussion Starter · #5 ·
yeah thats what the tires say, "44psi max". my last car (Geo metro)
only had 12 inch tires and they were about the same too, 44 psi
Yeah, do not go over the max PSI, im guessin the front tires are the ones you are talking about? usually thats cuz the engine unless you got weight in the back then the rear tires might look low.
Theres a keyword on your tire "MAX" that doesn't mean thats what you are suppose to run. If you look in the door jam or on the door there is usually a sticker that will tell you what the people who engineered the car recommend you run. I would run around 28-32 psi if it was me.
Discussion Starter · #9 ·
thanks alot for the help guys
Discussion Starter · #11 ·
i didnt find it, ill have to look a little harder i guess
1 - 12 of 12 Posts
